Sears Model 3351 132.802
Now that mowing season is over and some other honey dew projects are finish back to the radio. The poor thing has been sitting on my work bench for months. installed the tuner with new washers and tried the set, wow it works for like 20 minutes and then nothing. The 50 ohm resistor (R2) was very warm but checked out ok. turned set upright and it plays for like 10 minutes and stops. Back on its side and I stared pressing on stuff to see if something is loose and I press on a cap (C8) and it starts to play remove pressure and it stops. Will try and work on this poor thing some during the week.
Sears Model 3351 132.802 - by David - 05-20-2018, 06:05 PM
RE: Sears Model 3351 132.802 - by David - 05-20-2018, 06:07 PM
RE: Sears Model 3351 132.802 - by Paul Philco322 - 05-20-2018, 06:18 PM
RE: Sears Model 3351 132.802 - by David - 05-20-2018, 06:37 PM
RE: Sears Model 3351 132.802 - by 35Z5 - 05-20-2018, 07:08 PM
RE: Sears Model 3351 132.802 - by David - 05-20-2018, 08:37 PM
RE: Sears Model 3351 132.802 - by Paul Philco322 - 05-20-2018, 09:16 PM
RE: Sears Model 3351 132.802 - by Arran - 05-21-2018, 04:35 AM
RE: Sears Model 3351 132.802 - by 35Z5 - 05-21-2018, 08:38 AM
RE: Sears Model 3351 132.802 - by David - 05-24-2018, 05:55 PM
RE: Sears Model 3351 132.802 - by Arran - 05-25-2018, 05:52 AM
RE: Sears Model 3351 132.802 - by 35Z5 - 05-25-2018, 10:23 AM
RE: Sears Model 3351 132.802 - by David - 05-27-2018, 01:04 PM
RE: Sears Model 3351 132.802 - by David - 05-30-2018, 04:34 PM
RE: Sears Model 3351 132.802 - by David - 06-12-2018, 07:48 PM
RE: Sears Model 3351 132.802 - by David - 07-14-2018, 08:15 PM
RE: Sears Model 3351 132.802 - by David - 10-28-2018, 08:47 PM
RE: Sears Model 3351 132.802 - by 35Z5 - 10-29-2018, 10:31 AM
RE: Sears Model 3351 132.802 - by David - 10-29-2018, 05:08 PM
There are currently 10379 online users. [Complete List]
» 1 Member(s) | 10378 Guest(s)
