Zenith 6-S-147 Chairside
No. I doubt it. I'll have to confirm tomorrow, but solid wood would be expensive and prone to warping.
Zenith 6-S-147 Chairside - by Patrick - 10-28-2018, 04:33 PM
RE: Zenith 6-S-147 Chairside - by Phlogiston - 10-28-2018, 07:37 PM
RE: Zenith 6-S-147 Chairside - by Patrick - 10-28-2018, 08:40 PM
RE: Zenith 6-S-147 Chairside - by Phlogiston - 10-28-2018, 09:18 PM
RE: Zenith 6-S-147 Chairside - by Arran - 10-29-2018, 03:55 AM
RE: Zenith 6-S-147 Chairside - by Patrick - 10-29-2018, 05:44 AM
RE: Zenith 6-S-147 Chairside - by Arran - 11-01-2018, 12:11 AM
There are currently 9171 online users. [Complete List]
» 1 Member(s) | 9170 Guest(s)
