Zenith 6-S-147 Chairside
I'll have to research Austrailian walnut. The only reference I could find to the type of wood, said "Oriental walnut". This pic I received on the other site does show veneer.
[Image: http://i1367.photobucket.com/albums/r796...eihpxh.jpg]
It looks like it might be a challange to route out the interior for the veneer.
Pat
Zenith 6-S-147 Chairside - by Patrick - 10-28-2018, 04:33 PM
RE: Zenith 6-S-147 Chairside - by Phlogiston - 10-28-2018, 07:37 PM
RE: Zenith 6-S-147 Chairside - by Patrick - 10-28-2018, 08:40 PM
RE: Zenith 6-S-147 Chairside - by Phlogiston - 10-28-2018, 09:18 PM
RE: Zenith 6-S-147 Chairside - by Arran - 10-29-2018, 03:55 AM
RE: Zenith 6-S-147 Chairside - by Patrick - 10-29-2018, 05:44 AM
RE: Zenith 6-S-147 Chairside - by Arran - 11-01-2018, 12:11 AM
There are currently 10493 online users. [Complete List]
» 4 Member(s) | 10489 Guest(s)
AvatarAvatarAvatarAvatar
