42-350 tuning condenser. Never worked on this.
This tuning condenser has 4 gangs. But 2 are single blade (I would imagine SW and FM?). I didn't mark them when I removed them, and I'm lost as to proper hook-up.
I know the tuner is #14. One tab is connected to pin 2 of #7 (the FM oscill. trans.), one is connected to pin 7 of #7, one to C-3/C-4, and one to B-4.
But for the life of me, I can't figure out which! Can someone help?
Pat
[Image: http://i1367.photobucket.com/albums/r796...ozv5t3.jpg]
[Image: http://i1367.photobucket.com/albums/r796...nzyvg3.jpg]
42-350 tuning condenser. Never worked on this. - by Patrick - 10-30-2018, 05:27 PM
91H Code 126 Restore
