Zenith 6-S-147 Chairside
I'm not 100% certain but I think that Oriental Walnut and Australian Walnut are just different names for the same species of tree, which grows in Queensland. though in that last photo it does look a lot like Australian Walnut. I've also heard another name of "Orientalwood" in some cabinet descriptions from back then, but it may just be a marketing name.
Zenith 6-S-147 Chairside - by Patrick - 10-28-2018, 04:33 PM
RE: Zenith 6-S-147 Chairside - by Phlogiston - 10-28-2018, 07:37 PM
RE: Zenith 6-S-147 Chairside - by Patrick - 10-28-2018, 08:40 PM
RE: Zenith 6-S-147 Chairside - by Phlogiston - 10-28-2018, 09:18 PM
RE: Zenith 6-S-147 Chairside - by Arran - 10-29-2018, 03:55 AM
RE: Zenith 6-S-147 Chairside - by Patrick - 10-29-2018, 05:44 AM
RE: Zenith 6-S-147 Chairside - by Arran - 11-01-2018, 12:11 AM
