Model 112 volume control value?
I am working on a 112 in a Bel Geddes cabinet...but the original volume control has been replaced with an incorrect one. I'd like to put a proper one in...but no schematic or parts list I have in my library lists the value of the control. Only the part #, which is 4093.
Would anyone have a value for this control?
Model 112 volume control value? - by Brad Winder - 11-03-2018, 12:53 AM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4874 online users. [Complete List]
» 1 Member(s) | 4873 Guest(s)
