A 66B restore
Having finished the 66B chassis, its time to start the cabinet.  Here's the as received:
[Image: https://www.dropbox.com/s/ymrexcaqo4xwfa....jpg?raw=1]
This cabinet is actually in pretty nice shape although the finish is not good it is nice and solid.  So far just the usual strip and glue down a couple of veneer corners that are starting to lift off.
[Image: https://www.dropbox.com/s/sklxgv0an95wkl....jpg?raw=1]
[Image: https://www.dropbox.com/s/hqxwf4ee30pern....jpg?raw=1]
When stripping the cabinet there have been more times than I care to admit that I've forgotten to measure the position of the PHILCO decal.  So this time I made sure I had the measurements.  I imagine at the factory they did so many of them that it came naturally to just position the thing.
[Image: https://www.dropbox.com/s/wn0kwi7uef22sz....jpg?raw=1]
A 66B restore - by klondike98 - 11-04-2018, 11:46 AM
RE: A 66B restore - by klondike98 - 11-04-2018, 03:34 PM
RE: A 66B restore - by Radioroslyn - 11-04-2018, 05:34 PM
RE: A 66B restore - by klondike98 - 11-04-2018, 07:47 PM
RE: A 66B restore - by Ron Ramirez - 11-04-2018, 08:07 PM
RE: A 66B restore - by klondike98 - 11-04-2018, 08:29 PM
RE: A 66B restore - by Arran - 11-09-2018, 04:19 AM
