1933 60L Restoration
>The sch shows the cap of 0.18uF which is physically a bakelite with the two caps, two of the ends connected to the GND screw
Just to clear up perhaps a little confusion I'm not sure why but Philco back in the late '20s used .09mfd caps and continued to use them in to the '30s. It's a non standard value. That's how your model 60 has a .18mfd it's two .09's in parallel. Perfectly fine to use a couple of .1mfd cap to replace the .18mfd.
1933 60L Restoration - by Greggshere - 10-26-2018, 10:47 PM
RE: 60L Resistor Wattages - by Phlogiston - 10-27-2018, 09:59 AM
RE: 60L Resistor Wattages - by Greggshere - 10-27-2018, 12:26 PM
RE: 1933 60L Restoration - by Greggshere - 10-27-2018, 07:06 PM
RE: 1933 60L Restoration - by Greggshere - 10-27-2018, 07:13 PM
RE: 1933 60L Restoration - by Radioroslyn - 10-27-2018, 09:22 PM
RE: 1933 60L Restoration - by Greggshere - 10-28-2018, 06:20 PM
RE: 1933 60L Restoration - by jcassity - 10-31-2018, 10:02 AM
RE: 1933 60L Restoration - by Greggshere - 10-31-2018, 11:01 PM
RE: 1933 60L Restoration - by Greggshere - 11-03-2018, 10:43 AM
RE: 1933 60L Restoration - by klondike98 - 11-03-2018, 11:12 AM
RE: 1933 60L Restoration - by Greggshere - 11-03-2018, 02:03 PM
RE: 1933 60L Restoration - by Greggshere - 11-04-2018, 08:44 PM
RE: 1933 60L Restoration - by morzh - 11-04-2018, 08:56 PM
RE: 1933 60L Restoration - by Greggshere - 11-04-2018, 09:26 PM
RE: 1933 60L Restoration - by morzh - 11-04-2018, 09:47 PM
RE: 1933 60L Restoration - by klondike98 - 11-04-2018, 10:24 PM
RE: 1933 60L Restoration - by Greggshere - 11-04-2018, 11:44 PM
RE: 1933 60L Restoration - by Radioroslyn - 11-05-2018, 12:26 AM
RE: 1933 60L Restoration - by Greggshere - 11-05-2018, 01:16 AM
RE: 1933 60L Restoration - by morzh - 11-05-2018, 08:54 AM
RE: 1933 60L Restoration - by morzh - 11-05-2018, 09:01 AM
RE: 1933 60L Restoration - by Arran - 11-07-2018, 05:21 AM
RE: 1933 60L Restoration - by Greggshere - 11-07-2018, 11:01 AM
91H Code 126 Restore
