Was gifted a
Philco 48-145 set on the way to Kutztown. Got a chance to play with it and it's a surprising good player. Someone had recapped it so all there was to was hook up some batteries to it. Yes it's a 1 1/2v farm set. Low current design 200ma for the filaments and abt 6ma for the HV. At 6ma (abt what a 6 transistor uses) the B batteries should last a long time maybe + 30hrs. Not sure how long the A batteries will go. Good sensitivity and w/it's 6"spkr sound great. No hum and ac line interference.
Got some parts coming to build a battery box so they can be fitted into the back of the radio.
Tnx
Was gifted a - by Radioroslyn - 11-07-2018, 10:39 PM
RE: Was gifted a - by OldRestorer - 11-08-2018, 07:26 AM
RE: Was gifted a - by morzh - 11-08-2018, 09:25 AM
RE: Was gifted a - by Arran - 11-09-2018, 12:40 AM
RE: Was gifted a - by Farm Radio - 11-20-2018, 10:14 PM
RE: Was gifted a - by Radioroslyn - 11-21-2018, 01:08 PM
RE: Was gifted a - by Arran - 11-22-2018, 02:56 AM
RE: Was gifted a - by Radioroslyn - 11-22-2018, 11:31 AM
There are currently 8798 online users. [Complete List]
» 3 Member(s) | 8795 Guest(s)
