Philco 38-690 alignment questions
All electrolytics were replaced. Or re-stuffed, I should say. I preferred to keep the original look of Philco's capacitors. Some paper caps too, but not many. Actually all I replaced was located in the lower chassis. The receiver - everything I measured was within the tolerance.
So, I think you are right. I will not try to improve perfectly working radio.
Philco 38-690 alignment questions - by Ragazzo - 09-21-2010, 06:23 PM
Re: Philco 38-690 alignment questions - by Ragazzo - 09-23-2010, 06:05 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
