Philco 32-8248 power transformer
Thank you so much. I am scratch building a stereo tube amp and possibly going to use the power transformer and 6v6 outputs should be fun!!
Philco 32-8248 power transformer - by Marko - 11-10-2018, 08:32 AM
RE: Philco 32-8248 power transformer - by KCMike - 11-10-2018, 10:31 AM
RE: Philco 32-8248 power transformer - by Marko - 11-10-2018, 10:49 AM
RE: Philco 32-8248 power transformer - by morzh - 11-10-2018, 11:27 AM
RE: Philco 32-8248 power transformer - by Marko - 11-10-2018, 08:17 PM
RE: Philco 32-8248 power transformer - by morzh - 11-10-2018, 09:51 PM
RE: Philco 32-8248 power transformer - by Marko - 03-26-2019, 12:35 PM
There are currently 9165 online users. [Complete List]
» 2 Member(s) | 9163 Guest(s)
