Strange acting Crosley AA5
>> As normal I'm confused.
That makes two of us! Icon_lol
>>When you tune in a station and it plays for several seconds does the set not receive any more?
I can tune the dial slightly and the same station will come in again, for only a second or two.
>>Set is dead??
No, not dead just doesn't hold stations.
>>If you tune it to another station does it just play for a few seconds too??
Yes, then they fade away quickly too.
RE: Strange acting Crosley AA5 - by Radioroslyn - 11-10-2018, 09:05 PM
RE: Strange acting Crosley AA5 - by NostalgiaRadioTime - 11-10-2018, 09:16 PM
RE: Strange acting Crosley AA5 - by Radioroslyn - 11-10-2018, 09:25 PM
RE: Strange acting Crosley AA5 - by David - 11-10-2018, 09:37 PM
RE: Strange acting Crosley AA5 - by Radioroslyn - 11-11-2018, 10:26 AM
RE: Strange acting Crosley AA5 - by Radioroslyn - 11-11-2018, 01:21 PM
RE: Strange acting Crosley AA5 - by David - 11-11-2018, 07:30 PM
