Rubber covered wire
I agree with Ex. Another alternative is using heat shrink. You remove one end of the wire, and slip it over (after removing the old rubber insulation, which usually can be crumbled off), then heat it to shrink. Make/be extra careful when using flame to shrink it. Don't get get near a coil with a flame.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Rubber covered wire - by w4rtc - 09-24-2010, 04:02 PM
Re: Rubber covered wire - by exray - 09-24-2010, 05:40 PM
Re: Rubber covered wire - by BDM - 09-25-2010, 09:58 AM
Re: Rubber covered wire - by Ron Ramirez - 09-25-2010, 10:16 AM
Re: Rubber covered wire - by BDM - 09-25-2010, 10:25 AM
Re: Rubber covered wire - by Ron Ramirez - 09-25-2010, 10:34 AM
Re: Rubber covered wire - by BDM - 09-25-2010, 10:45 AM
Re: Rubber covered wire - by DeckApe - 09-25-2010, 05:14 PM
Re: Rubber covered wire - by radiorich - 09-26-2010, 02:36 AM
Re: Rubber covered wire - by w4rtc - 09-26-2010, 11:00 PM
Re: Rubber covered wire - by radiorich - 09-27-2010, 12:25 AM
Re: Rubber covered wire - by DeckApe - 10-02-2010, 11:40 AM
Re: Rubber covered wire - by Ron Ramirez - 10-03-2010, 09:39 AM
Re: Rubber covered wire - by w4rtc - 10-07-2010, 11:55 PM
Re: Rubber covered wire - by radiorich - 10-12-2010, 02:39 PM
Re: Rubber covered wire - by codefox1 - 10-12-2010, 05:26 PM
Re: Rubber covered wire - by Ron Ramirez - 10-12-2010, 06:39 PM
Re: Rubber covered wire - by exray - 10-12-2010, 07:48 PM
