  • 1 Vote(s) - 5 Average
Philco 444
    How does one re edit a picture for a smaller size? I attempted to add multiple pictures last night and ended up with the same image twice. Today that image wont work and this was in a saved draft that I used for the first post above. This lousy photo is only 340KB and the rest of what I got are 1.198 megs up to 2.7megs. Nowadays file sizes are not very small with cameras and phone cameras
Philco 444 - by Philco444 - 11-12-2018, 09:21 PM
RE: Philco 444 - by Philco444 - 11-12-2018, 09:36 PM
RE: Philco 444 - by klondike98 - 11-12-2018, 09:41 PM
RE: Philco 444 - by Philco444 - 11-12-2018, 09:42 PM
RE: Philco 444 - by Philco444 - 11-12-2018, 09:45 PM
RE: Philco 444 - by klondike98 - 11-12-2018, 09:49 PM
RE: Philco 444 - by Philco444 - 11-12-2018, 09:57 PM
RE: Philco 444 - by Philco444 - 11-12-2018, 10:00 PM
RE: Philco 444 - by klondike98 - 11-12-2018, 11:56 PM
RE: Philco 444 - by Arran - 11-13-2018, 03:55 AM
RE: Philco 444 - by Chas - 11-13-2018, 10:19 AM
RE: Philco 444 - by Philco444 - 11-13-2018, 09:22 PM
RE: Philco 444 - by Arran - 11-16-2018, 05:02 AM
RE: Philco 444 - by Philco444 - 11-19-2018, 03:36 PM
RE: Philco 444 - by Philco444 - 11-19-2018, 03:41 PM
RE: Philco 444 - by Philco444 - 11-19-2018, 03:42 PM
RE: Philco 444 - by Philco444 - 11-19-2018, 03:52 PM
RE: Philco 444 - by Ron Ramirez - 11-19-2018, 11:01 PM
