  • 1 Vote(s) - 5 Average
Nuvistor
Introduced by RCA in early '60s, used extensively in their TV tuners as RF amp. Sold(leased?) to Sylvania in the '70s when RCA discontinued tube production. Were versions for aerospace, commercial and even in a antenna mounted amplifier to improve TV reception in fringe areas.
Tom
Nuvistor - by jcassity - 11-13-2018, 11:00 AM
RE: Nuvistor - by 35Z5 - 11-13-2018, 11:33 AM
RE: Nuvistor - by EdHolland - 11-13-2018, 01:22 PM
RE: Nuvistor - by Ron Ramirez - 11-13-2018, 02:00 PM
RE: Nuvistor - by EdHolland - 11-13-2018, 02:51 PM
RE: Nuvistor - by morzh - 11-13-2018, 09:19 PM
RE: Nuvistor - by RadioSvit - 11-14-2018, 05:36 PM
RE: Nuvistor - by Arran - 11-16-2018, 01:13 AM
RE: Nuvistor - by morzh - 11-16-2018, 11:47 AM
There are currently 3701 online users. [Complete List]
» 1 Member(s) | 3700 Guest(s)
