1925 Apex Super
I just jumped around the "Nov Finds" and went strait to FINISHED.
https://www.russoldradios.com/blog
The cabinet took a few days.
1925 Apex Super - by Phlogiston - 11-13-2018, 01:19 PM
RE: 1925 Apex Super - by klondike98 - 11-13-2018, 02:14 PM
RE: 1925 Apex Super - by EdHolland - 11-13-2018, 02:48 PM
There are currently 10467 online users. [Complete List]
» 2 Member(s) | 10465 Guest(s)
