Philco 118B Cabinet resto
Hello, Ron: I have a 118B I recently did a chassis resto on. It is a FANTASTIC player now.
However, the cabinet will be "challenging." I must "reskin the cabinet side about 1/2 way down one side of the cabinet.
What kind of veneer should I use for this?
Additionally, what color toners do you recommend. I think the sides and portions of the front would be dark or extra dark walnut, the two "scallops" in front a light walnut or even left natural. BUT, the original center portion appeared to be more of a red color.
Tom
Philco 118B Cabinet resto - by TA Forbes - 09-27-2010, 11:18 AM
Re: Philco 118B Cabinet resto - by Ron Ramirez - 09-27-2010, 11:49 AM
There are currently 9204 online users. [Complete List]
» 3 Member(s) | 9201 Guest(s)
