53-706 winter project
This particular model has a dial lamp, a clock, and is a desk lamp/ am radio.
53-706 winter project - by SteveinAlaska - 11-12-2018, 11:41 PM
RE: 53-706 winter project - by David - 11-13-2018, 08:23 AM
RE: 53-706 winter project - by SteveinAlaska - 11-13-2018, 03:29 PM
RE: 53-706 winter project - by Radioroslyn - 11-13-2018, 06:47 PM
RE: 53-706 winter project - by SteveinAlaska - 11-14-2018, 02:47 AM
RE: 53-706 winter project - by David - 11-14-2018, 08:30 AM
RE: 53-706 winter project - by Radioroslyn - 11-14-2018, 11:44 AM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 3544 online users. [Complete List]
» 2 Member(s) | 3542 Guest(s)
