HOWDY!!
I build airplanes, so I have some knowledge of electronics. This is different because it's older components. I learned basically what it took to make me good enough at what part of the process i do, which doesn't involve an oscilliscope lol. Reason I asked is that terminology changes over the years and I honestly didn't know what parts I needed. Thanks for the input though, I'll give those a long look!
HOWDY!! - by jfloate - 11-13-2018, 09:28 PM
RE: HOWDY!! - by KCMike - 11-13-2018, 10:12 PM
RE: HOWDY!! - by klondike98 - 11-13-2018, 10:57 PM
RE: HOWDY!! - by jfloate - 11-14-2018, 07:41 PM
There are currently 3085 online users. [Complete List]
» 1 Member(s) | 3084 Guest(s)
