Philco Highboy 96 Chassis
$50 Canuck beaver pelts worth prob $30US. I will buy some diapers and baby formula, powder, etc.
Any idea what models used this chassis? It comes with the speaker as well and I don't know what size it is but most likely it is a typical Philco speaker with the metal thingy in the middle. Looks heavy and well built anyway. How extinct are these cabinets and what variations can I hope to use as a politically correct home for this chassis?
Philco Highboy 96 Chassis - by Philco444 - 11-14-2018, 08:58 PM
RE: Philco Highboy 96 Chassis - by morzh - 11-14-2018, 09:08 PM
RE: Philco Highboy 96 Chassis - by Philco444 - 11-14-2018, 10:20 PM
RE: Philco Highboy 96 Chassis - by klondike98 - 11-14-2018, 10:23 PM
RE: Philco Highboy 96 Chassis - by morzh - 11-14-2018, 10:31 PM
RE: Philco Highboy 96 Chassis - by Philco444 - 11-14-2018, 11:28 PM
RE: Philco Highboy 96 Chassis - by morzh - 11-14-2018, 11:48 PM
RE: Philco Highboy 96 Chassis - by Philco444 - 11-16-2018, 01:39 AM
RE: Philco Highboy 96 Chassis - by Arran - 11-16-2018, 04:46 AM
RE: Philco Highboy 96 Chassis - by morzh - 11-16-2018, 09:28 AM
RE: Philco Highboy 96 Chassis - by Philco444 - 11-16-2018, 05:40 PM
RE: Philco Highboy 96 Chassis - by Philco444 - 11-20-2018, 05:11 PM
