Philco Highboy 96 Chassis
What models? Model 96.
It might fit (can't be sure but lkely)
511, 30, 40, 4, 76, 7, 86, 531, 551, 65, 87, 95, 96, 296, 111, 112.
All made before 1931, the last two are superhets.
Philco Highboy 96 Chassis - by Philco444 - 11-14-2018, 08:58 PM
RE: Philco Highboy 96 Chassis - by morzh - 11-14-2018, 09:08 PM
RE: Philco Highboy 96 Chassis - by Philco444 - 11-14-2018, 10:20 PM
RE: Philco Highboy 96 Chassis - by klondike98 - 11-14-2018, 10:23 PM
RE: Philco Highboy 96 Chassis - by morzh - 11-14-2018, 10:31 PM
RE: Philco Highboy 96 Chassis - by Philco444 - 11-14-2018, 11:28 PM
RE: Philco Highboy 96 Chassis - by morzh - 11-14-2018, 11:48 PM
RE: Philco Highboy 96 Chassis - by Philco444 - 11-16-2018, 01:39 AM
RE: Philco Highboy 96 Chassis - by Arran - 11-16-2018, 04:46 AM
RE: Philco Highboy 96 Chassis - by morzh - 11-16-2018, 09:28 AM
RE: Philco Highboy 96 Chassis - by Philco444 - 11-16-2018, 05:40 PM
RE: Philco Highboy 96 Chassis - by Philco444 - 11-20-2018, 05:11 PM
