Is this 20 or 21?
https://www.radiomuseum.org/r/philco_cat..._20_e.html
So, there was a 20-E model after all.....it is probably a European version as it says "230V 50-60Hz".
Otherwise it is exactly the same as 21.
The guy found that and this is why he though it was a 20-E, but his is 21.
Is this 20 or 21? - by morzh - 11-14-2018, 03:39 PM
RE: Is this 20 or 21? - by Radioroslyn - 11-14-2018, 04:25 PM
RE: Is this 20 or 21? - by Ron Ramirez - 11-14-2018, 04:31 PM
RE: Is this 20 or 21? - by morzh - 11-14-2018, 04:47 PM
RE: Is this 20 or 21? - by Ron Ramirez - 11-14-2018, 04:49 PM
RE: Is this 20 or 21? - by morzh - 11-14-2018, 04:53 PM
RE: Is this 20 or 21? - by morzh - 11-15-2018, 01:13 PM
RE: Is this 20 or 21? - by Ron Ramirez - 11-15-2018, 03:26 PM
