Potentiometers
1. Take a rotating multi-point switch.
2. Solder resistors according to the values and the taper function,
3. Solder in and enjoy.
Potentiometers - by EdHolland - 11-13-2018, 01:37 PM
RE: Potentiometers - by Phlogiston - 11-13-2018, 01:50 PM
RE: Potentiometers - by EdHolland - 11-13-2018, 03:20 PM
RE: Potentiometers - by Chas - 11-13-2018, 10:32 PM
RE: Potentiometers - by Radioroslyn - 11-13-2018, 11:24 PM
RE: Potentiometers - by EdHolland - 11-14-2018, 02:52 PM
RE: Potentiometers - by Chas - 11-14-2018, 05:39 PM
RE: Potentiometers - by EdHolland - 11-15-2018, 01:50 PM
RE: Potentiometers - by morzh - 11-15-2018, 02:24 PM
RE: Potentiometers - by EdHolland - 11-15-2018, 05:02 PM
RE: Potentiometers - by EdHolland - 11-18-2018, 12:01 AM
There are currently 6018 online users. [Complete List]
» 2 Member(s) | 6016 Guest(s)
