Echophone S-4 Question and Show & Tell
I tried the DIY water slide approach once and the decal was so fragile I could not make it work...maybe I had a bad product. Both of those applications look great!
Icon_thumbup
RE: Echophone S-4 Question and Show & Tell - by klondike98 - 11-17-2018, 12:31 PM
