46-480 questions: style of grill cloth and do repro pushbutton clear covers exist?
Hi all!
New to Phorum and restoring a 46-480.  What style grill cloth is needed, and do the clear covers exist for the pushbuttons?  From what I’ve seen so far those appear to be made of that most precious material known as unobtainium...
46-480 questions: style of grill cloth and do repro pushbutton clear covers exist? - by DuMont - 11-19-2018, 09:51 AM
There are currently 8401 online users. [Complete List]
» 1 Member(s) | 8400 Guest(s)
