Philco 650 K-17 Speaker Transformer
Hello Everyone,
I am having issues with a K-17 speaker. The output transformer was bad and I need to replace it. I'm having trouble crossing the 32-7078 transformer. I bought a Hammonds 125D universal push-pull, but and not sure how to wire it up. Anybody have experience with this and can point me in the right direction?
Thank You in advance.
Matt
Philco 650 K-17 Speaker Transformer - by wardmc1 - 11-20-2018, 02:23 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4871 online users. [Complete List]
» 1 Member(s) | 4870 Guest(s)
