Philco Highboy 96 Chassis
Hi Arran
I just got through looking at Canadian CL, looked throughout Canada and major cities. Obviously not as good as American CL prob due to population etc. and the selection is quite simply limited with few and far between. The menue is very limited and Kijiji you search antique radio this is what you get. I even searched CL in major cities for Samsung Galaxie well forget it. But This is my opinion and if you see a collector or somebody with an item for sale on Kijiggle you can contact and dicker or see what else they have and YES you can send personal email and not get suspended like eBay. Even for the closest city Saskatoon I search Samsung and get an assortment of those who tried and switch back to Apple or cannot afford the higher monthly $ after upgrading. This 5C I have is like a bird flying around in a cage.
Philco Highboy 96 Chassis - by Philco444 - 11-14-2018, 08:58 PM
RE: Philco Highboy 96 Chassis - by morzh - 11-14-2018, 09:08 PM
RE: Philco Highboy 96 Chassis - by Philco444 - 11-14-2018, 10:20 PM
RE: Philco Highboy 96 Chassis - by klondike98 - 11-14-2018, 10:23 PM
RE: Philco Highboy 96 Chassis - by morzh - 11-14-2018, 10:31 PM
RE: Philco Highboy 96 Chassis - by Philco444 - 11-14-2018, 11:28 PM
RE: Philco Highboy 96 Chassis - by morzh - 11-14-2018, 11:48 PM
RE: Philco Highboy 96 Chassis - by Philco444 - 11-16-2018, 01:39 AM
RE: Philco Highboy 96 Chassis - by Arran - 11-16-2018, 04:46 AM
RE: Philco Highboy 96 Chassis - by morzh - 11-16-2018, 09:28 AM
RE: Philco Highboy 96 Chassis - by Philco444 - 11-16-2018, 05:40 PM
RE: Philco Highboy 96 Chassis - by Philco444 - 11-20-2018, 05:11 PM
There are currently 10291 online users. [Complete List]
» 1 Member(s) | 10290 Guest(s)
