Echophone S-4 Question and Show & Tell
Henry;
  I would go back and replace that 2 uf with a non polarized capacitor, either a large film cap or a motor run cap, modern low value electrolytics apparently can't take the ripple current found in old radio power supplies and don't live very long. The originals were probably large paper capacitors to start with, sort of like a Radiola 18 or a Philco 20, not electrolytics.
RE: Echophone S-4 Question and Show & Tell - by Arran - 11-22-2018, 03:41 AM
There are currently 9993 online users. [Complete List]
» 4 Member(s) | 9989 Guest(s)
AvatarAvatarAvatarAvatar
