ATWATER KENT 82
+1 what Russ said. Nevertheless, while I savor a just-finished delicious Thanksgiving dinner and let the tryptophan do its thing...and since I feel good enough today to do this...Ed, let me translate the entire exchange for you.
Ferran Wrote:Good Morning,
I am restoring an ATWATER KENT, model 82. One of the missing parts is the potentiometer. It is a potentiometer with a 550 ohm switch.
Could someone advise me where to find the component? Original or similar?
Thanks and regards,
Ferran
morzh Wrote:Ferran, try Mark Oppat.
http://www.oldradioparts.net
Ferran Wrote:Thank you !!!!
Grateful.
Best regards,
Ferran
The web page that you have passed me, fantastic.
On Friday I will send the potentiometer.
Thanks again.
Icon_smile
ATWATER KENT 82 - by ducretet - 11-21-2018, 04:07 AM
RE: ATWATER KENT 82 - by morzh - 11-21-2018, 09:00 AM
RE: ATWATER KENT 82 - by ducretet - 11-21-2018, 10:19 AM
RE: ATWATER KENT 82 - by ducretet - 11-22-2018, 02:23 AM
RE: ATWATER KENT 82 - by Ed Locker - 11-22-2018, 11:01 AM
RE: ATWATER KENT 82 - by Phlogiston - 11-22-2018, 12:04 PM
RE: ATWATER KENT 82 - by Ron Ramirez - 11-22-2018, 01:21 PM
RE: ATWATER KENT 82 - by morzh - 11-22-2018, 01:22 PM
RE: ATWATER KENT 82 - by ducretet - 11-22-2018, 01:47 PM
RE: ATWATER KENT 82 - by Phlogiston - 11-22-2018, 01:53 PM
There are currently 8590 online users. [Complete List]
» 1 Member(s) | 8589 Guest(s)
