Model 89L Philco tallboy circa 1933
Actually Ron, my tallboy after work is a long-stemmed, double Martini.
8)
Model 89L Philco tallboy circa 1933 - by Guest - 09-30-2010, 05:32 PM
Re: Model 89L Philco tallboy circa 1933 - by Chuck Schwark - 10-01-2010, 01:12 PM
There are currently 10515 online users. [Complete List]
» 2 Member(s) | 10513 Guest(s)
