Crosley Bandbox 601 / What could go wrong??
So after a long hiatus I got busy on the 601, actually I was getting tired moving it around the work bench and it's three times a big when it's in pieces. I thought I had some pics of it around but can't seem to find them.
Found an online schematic (redrawn) but I think there is a error in the filament wiring. flashvol25_iss2(7).pdf I'll sort it when I power it up. It's all pretty much wired up but needs a good cleaning.
RE: What could go wrong??? - by OldRestorer - 08-22-2017, 06:00 PM
RE: What could go wrong??? - by Radioroslyn - 08-22-2017, 06:05 PM
RE: What could go wrong??? - by sam - 08-22-2017, 09:15 PM
RE: What could go wrong??? - by OldRestorer - 08-22-2017, 10:36 PM
RE: What could go wrong??? - by sam - 08-22-2017, 11:53 PM
RE: What could go wrong??? - by Eliot Ness - 08-23-2017, 08:41 AM
RE: What could go wrong??? - by Radioroslyn - 08-23-2017, 12:31 PM
RE: What could go wrong??? - by morzh - 08-23-2017, 12:51 PM
RE: What could go wrong??? - by klondike98 - 08-23-2017, 01:20 PM
RE: What could go wrong??? - by WallaceRoger - 08-23-2017, 02:25 PM
RE: What could go wrong??? - by Radioroslyn - 08-23-2017, 02:46 PM
RE: What could go wrong??? - by Radioroslyn - 08-23-2017, 06:32 PM
RE: What could go wrong??? - by OldRestorer - 08-23-2017, 07:36 PM
RE: What could go wrong??? - by WallaceRoger - 08-24-2017, 10:05 AM
RE: Crosley Bandbox 601 / What could go wrong?? - by Radioroslyn - 11-25-2018, 08:07 PM
There are currently 3531 online users. [Complete List]
» 1 Member(s) | 3530 Guest(s)
