Stromberg Carlson AWP-8
#44
Today I put it back together. The RF chassis cover went back easy after 2 minutes of looking at it. So it should have come out but then I was a bit too hot-headed to stop and think Icon_smile
What's missing is 4 bottom bolts. I guess I never had them, need to find some and bolt the chassis to the cabinet.
Surprisingly the original lights work. And the battery is coming from Ed.
I am at home, took a week off as I need to spend 3-1/2 weeks before the end of the year. Sitting at the window, looking at the rain outside. After working on a radio, after having a beer.....nice. Like it.
Stromberg Carlson AWP-8 - by morzh - 10-17-2018, 07:04 PM
RE: Stromberg Carlson AWP-8 - by sam - 10-17-2018, 07:07 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-17-2018, 07:21 PM
RE: Stromberg Carlson AWP-8 - by sam - 10-17-2018, 07:28 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-17-2018, 07:31 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-17-2018, 09:01 PM
RE: Stromberg Carlson AWP-8 - by KCMike - 10-17-2018, 09:13 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-17-2018, 10:39 PM
RE: Stromberg Carlson AWP-8 - by sam - 10-17-2018, 10:53 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-17-2018, 10:56 PM
RE: Stromberg Carlson AWP-8 - by Chas - 10-18-2018, 08:41 AM
RE: Stromberg Carlson AWP-8 - by morzh - 10-18-2018, 09:09 AM
RE: Stromberg Carlson AWP-8 - by Radioroslyn - 10-18-2018, 09:18 AM
RE: Stromberg Carlson AWP-8 - by EdHolland - 10-18-2018, 12:25 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-18-2018, 03:49 PM
RE: Stromberg Carlson AWP-8 - by KCMike - 10-18-2018, 04:36 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-18-2018, 04:42 PM
RE: Stromberg Carlson AWP-8 - by KCMike - 10-18-2018, 04:51 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-18-2018, 04:54 PM
RE: Stromberg Carlson AWP-8 - by EdHolland - 10-18-2018, 08:09 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-18-2018, 09:48 PM
RE: Stromberg Carlson AWP-8 - by Eliot Ness - 10-19-2018, 08:26 AM
RE: Stromberg Carlson AWP-8 - by morzh - 10-19-2018, 09:13 AM
RE: Stromberg Carlson AWP-8 - by morzh - 10-19-2018, 09:19 AM
RE: Stromberg Carlson AWP-8 - by morzh - 10-19-2018, 10:05 PM
RE: Stromberg Carlson AWP-8 - by kj0002 - 10-20-2018, 09:57 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-21-2018, 12:34 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-27-2018, 07:40 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-30-2018, 07:49 AM
RE: Stromberg Carlson AWP-8 - by Eliot Ness - 10-30-2018, 11:03 AM
RE: Stromberg Carlson AWP-8 - by Paul Philco322 - 10-30-2018, 11:09 AM
RE: Stromberg Carlson AWP-8 - by morzh - 10-30-2018, 01:57 PM
RE: Stromberg Carlson AWP-8 - by WyTex - 10-30-2018, 02:20 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-30-2018, 03:56 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-30-2018, 08:05 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-03-2018, 07:21 PM
RE: Stromberg Carlson AWP-8 - by Paul Philco322 - 11-03-2018, 07:57 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-04-2018, 01:39 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-04-2018, 08:04 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-11-2018, 06:24 PM
RE: Stromberg Carlson AWP-8 - by klondike98 - 11-11-2018, 07:09 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-11-2018, 08:08 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-23-2018, 01:18 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-26-2018, 03:54 PM
RE: Stromberg Carlson AWP-8 - by WyTex - 11-27-2018, 10:02 AM
RE: Stromberg Carlson AWP-8 - by morzh - 11-27-2018, 02:45 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-28-2018, 04:32 PM
RE: Stromberg Carlson AWP-8 - by morzh - 12-08-2018, 08:46 PM
Users browsing this thread: 18 Guest(s)
There are currently 10006 online users. [Complete List]
» 1 Member(s) | 10005 Guest(s)
