Veneer for a Model 87 Philco
Hello and welcome!
Walnut veneer was originally used; nothing fancy on the top, or on the bottom piece behind the decorative molding on bottom front, just plain walnut.
Veneer for a Model 87 Philco - by Guest - 09-27-2010, 12:44 PM
Re: Veneer for a Model 87 Philco - by Ron Ramirez - 10-03-2010, 12:00 PM
Re: Veneer for a Model 87 Philco - by 7estatdef - 10-03-2010, 08:42 PM
Re: Veneer for a Model 87 Philco - by Jim Skelly - 10-19-2010, 12:43 PM
There are currently 9761 online users. [Complete List]
» 1 Member(s) | 9760 Guest(s)
