My RCA 18T
RCA's documentation was among the best of any radio manufacturer until about 1937-38 when they started cutting back on info. The T7-5 (1936) I restored some months back and the 6T2 (1937) I'm currently working on have several pages of documentation. But, having Doug Houston's RCA Red Books, I can see that the later RCA models have considerably less documentation.
Good work on that 18T. Icon_thumbup
And Brad, you may be in for a surprise with your 39-3116. I have some Canadian Philcos made after 1938, and each one I have worked on has had mostly cloth-covered wiring - unlike their USA counterparts. You will run into some rubber-covered wiring. But I think you will find that most of it is cloth-covered.
My RCA 18T - by mikethedruid - 09-26-2018, 07:09 PM
RE: My RCA 18T - by Chas - 09-26-2018, 07:49 PM
RE: My RCA 18T - by Paul Philco322 - 09-26-2018, 08:49 PM
RE: My RCA 18T - by mikethedruid - 09-26-2018, 08:57 PM
RE: My RCA 18T - by mikethedruid - 09-27-2018, 07:10 PM
RE: My RCA 18T - by Ron Ramirez - 09-27-2018, 07:56 PM
RE: My RCA 18T - by mikethedruid - 11-28-2018, 10:55 PM
RE: My RCA 18T - by Brad Winder - 11-29-2018, 11:18 AM
RE: My RCA 18T - by EdHolland - 11-29-2018, 05:54 PM
RE: My RCA 18T - by Ron Ramirez - 11-29-2018, 08:01 PM
RE: My RCA 18T - by Paul Philco322 - 11-29-2018, 10:09 PM
RE: My RCA 18T - by mikethedruid - 11-29-2018, 10:39 PM
RE: My RCA 18T - by Paul Philco322 - 11-29-2018, 10:47 PM
RE: My RCA 18T - by mikethedruid - 11-30-2018, 07:27 PM
RE: My RCA 18T - by Paul Philco322 - 11-30-2018, 11:56 PM
There are currently 5718 online users. [Complete List]
» 1 Member(s) | 5717 Guest(s)
