Philco 38-690 Source for 630 volt Solen and Regular Electrolytic Capacitors.
I used higher rating for the caps that are parts of the primary rectifiers' (two of those) filters.
I serialized 22uF 450V high-ripple Panasonic caps to get 11uF of high-voltage capacitance where 8uF was needed.
the caps after the tweeters' field coils might be 450V as there is significant drop across them.
I am sure 450V is Ok too.
91H Code 126 Restore
There are currently 4008 online users. [Complete List]
» 3 Member(s) | 4005 Guest(s)
