Looking for recomendations for
They did use stains, or dyes, back then, but I think they used some sort of paint or sealer on the insides of cabinets. It may have been a mix of hide glue and a dye in some cases. Flat dark brown paint would be fine, like dark brown Bakelite colour, you don't have to be 100% accurate, I doubt if every cabinet of a given type was exactly the same, it probably varied from day to day, week to week, depending on who was doing the mixing, or what lot they used.
Looking for recomendations for - by Radioroslyn - 12-05-2018, 07:57 PM
RE: Looking for recomendations for - by Arran - 12-07-2018, 02:49 AM
RE: Looking for recomendations for - by jcassity - 12-21-2018, 07:04 PM
