16B find. They are YUGE!
I picked up this Philco 16B today, courtesy of a local radio guy who has an extraordinary collection of antique radios.  It's been tastefully refinished, and electronically restored.  I had no idea these things were such beasts.  It must weigh 50lbs.
Sounds great, and will look great in the living room once I move some things around.
[Image: https://i.imgur.com/mq3rwHI.jpg?1]
[Image: https://i.imgur.com/0WQMzLx.jpg?1]
[Image: https://i.imgur.com/YaFIbnW.jpg?1]
[Image: https://i.imgur.com/U42hVe5.jpg?1]
[Image: https://i.imgur.com/gPSaDLJ.jpg?1]
[Image: https://i.imgur.com/s6Cwu4Q.jpg?1]
16B find. They are YUGE! - by rdnzl - 12-07-2018, 05:38 PM
RE: 16B find. They are YUGE! - by Greggshere - 12-07-2018, 07:39 PM
RE: 16B find. They are YUGE! - by morzh - 12-07-2018, 07:45 PM
RE: 16B find. They are YUGE! - by rdnzl - 12-07-2018, 07:51 PM
RE: 16B find. They are YUGE! - by morzh - 12-07-2018, 07:54 PM
RE: 16B find. They are YUGE! - by Ron Ramirez - 12-07-2018, 08:02 PM
RE: 16B find. They are YUGE! - by rdnzl - 12-07-2018, 08:02 PM
RE: 16B find. They are YUGE! - by morzh - 12-07-2018, 08:37 PM
RE: 16B find. They are YUGE! - by Radioroslyn - 12-07-2018, 10:27 PM
RE: 16B find. They are YUGE! - by OldRestorer - 12-08-2018, 09:02 AM
RE: 16B find. They are YUGE! - by morzh - 12-08-2018, 12:46 PM
RE: 16B find. They are YUGE! - by Radioroslyn - 12-08-2018, 10:42 PM
RE: 16B find. They are YUGE! - by morzh - 12-09-2018, 12:20 AM
There are currently 10391 online users. [Complete List]
» 3 Member(s) | 10388 Guest(s)
