1941 Philco escutcheon Screws
I've trying to find the small Bronze colored oval head screws that attach the plastic dial cover on the 41 philcos. I've tried to use other screws , but they just do not look right.
Any suggestions ?
1941 Philco escutcheon Screws - by AJB49 - 10-09-2010, 10:08 AM
Re: 1941 Philco escutcheon Screws - by AJB49 - 10-16-2010, 08:05 AM
There are currently 9647 online users. [Complete List]
» 1 Member(s) | 9646 Guest(s)
