Philco 76-1134 Antenna Coupler (three prong)
I just bought a Philco 76-1134 antenna coupler for my Philco 41-250, and have the schematic which someone else drew.
This was first discussed (at least with me involved) in this thread where there are photos of the unit which Ron posted:
http://philcoradio.com/phorum/showthread.php?tid=1472
[Image: http://i269.photobucket.com/albums/jj77/...0001-3.jpg]
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
Philco 76-1134 Antenna Coupler (three prong) - by FStephenMasek - 10-09-2010, 07:20 PM
There are currently 8431 online users. [Complete List]
» 1 Member(s) | 8430 Guest(s)
