8G005 Zenith T/O Restoration
The Z1 battery is the 1.5v one right?
If so, here is where I found it in the first 8G005 I worked on. Left side, on the bottom when looking from the back. Don't know if that is where it was when the AB battery pack was in place, this one did not have that in it at the time.
[Image: https://www.dropbox.com/s/9sx44hi090lfcv....jpg?raw=1]
8G005 Zenith T/O Restoration - by morzh - 09-01-2018, 07:26 PM
RE: 8G005 Zenith T/O Restoration - by klondike98 - 09-02-2018, 09:08 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 09-02-2018, 11:12 PM
RE: 8G005 Zenith T/O Restoration - by Arran - 09-03-2018, 02:37 AM
RE: 8G005 Zenith T/O Restoration - by morzh - 09-03-2018, 05:10 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 09-10-2018, 09:05 AM
RE: 8G005 Zenith T/O Restoration - by morzh - 09-24-2018, 10:56 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 09-30-2018, 09:21 PM
RE: 8G005 Zenith T/O Restoration - by PhilcoJohn - 10-01-2018, 07:50 AM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-01-2018, 08:05 AM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-01-2018, 10:28 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-02-2018, 08:20 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-02-2018, 08:34 PM
RE: 8G005 Zenith T/O Restoration - by KCMike - 10-02-2018, 09:27 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-02-2018, 10:06 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-03-2018, 08:06 PM
RE: 8G005 Zenith T/O Restoration - by sam - 10-03-2018, 10:53 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-03-2018, 11:01 PM
RE: 8G005 Zenith T/O Restoration - by sam - 10-03-2018, 11:19 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-03-2018, 11:34 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-04-2018, 03:41 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-04-2018, 07:58 PM
RE: 8G005 Zenith T/O Restoration - by klondike98 - 10-04-2018, 09:54 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-04-2018, 10:34 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-05-2018, 10:10 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 11-29-2018, 10:01 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 12-08-2018, 07:34 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 12-08-2018, 08:44 PM
RE: 8G005 Zenith T/O Restoration - by klondike98 - 12-09-2018, 11:12 AM
RE: 8G005 Zenith T/O Restoration - by morzh - 12-09-2018, 11:39 AM
There are currently 10372 online users. [Complete List]
» 1 Member(s) | 10371 Guest(s)
