Another noob with another Philco!
I hope this shiny glittery stuff is not poly, then you will have to deal with it on the front panel.
RE: Another noob with another Philco! - by David - 12-12-2018, 09:34 AM
RE: Another noob with another Philco! - by morzh - 12-12-2018, 11:18 AM
Tube testing - by atlghosthunter - 01-05-2019, 04:27 AM
Philco 91 Tuning Condenser
There are currently 8858 online users. [Complete List]
» 2 Member(s) | 8856 Guest(s)
