17 Chassis
I picked up a 17 chassis Code 121 a few days ago and I'm wondering what I should do with it. The chassis appears complete, with the power cord and some other connecting wires having been replaced. There's no cabinet, but there is a small speaker. All tubes are present. It's a beast!
What would you do with it?
17 Chassis - by Dwartz Farquhartz - 12-13-2018, 05:42 PM
RE: 17 Chassis - by Radioroslyn - 12-13-2018, 07:41 PM
RE: 17 Chassis - by klondike98 - 12-13-2018, 08:36 PM
RE: 17 Chassis - by Steve Davis - 12-13-2018, 10:08 PM
RE: 17 Chassis - by Radioroslyn - 12-13-2018, 10:53 PM
RE: 17 Chassis - by Steve Davis - 12-14-2018, 07:58 AM
RE: 17 Chassis - by Steve Davis - 12-14-2018, 08:01 AM
RE: 17 Chassis - by Dwartz Farquhartz - 12-14-2018, 06:27 PM
There are currently 10545 online users. [Complete List]
» 2 Member(s) | 10543 Guest(s)
