Balkeit Model C
I was looking at an old catalog from the early 1930s, and they had a number of sets with cabinets made by Berkey and Gay Furniture, one of the makes was something called a "Cadillac" which I have never heard of, it may have been a private label brand, or the mail order outfit may have assembled them using surplus chassis installed into B&G cabinets. Balkeit was one of the larger independents started in the 1920s, whom had a few good years during the radio boom, then slowly faded, then went bust or merged into another firm.
Balkeit Model C - by rfeenstra - 12-11-2018, 11:48 PM
RE: Balkeit Model C - by rfeenstra - 12-11-2018, 11:51 PM
RE: Balkeit Model C - by Phlogiston - 12-12-2018, 11:56 AM
RE: Balkeit Model C - by rfeenstra - 12-12-2018, 01:30 PM
RE: Balkeit Model C - by Phlogiston - 12-12-2018, 03:15 PM
RE: Balkeit Model C - by rfeenstra - 12-12-2018, 07:02 PM
RE: Balkeit Model C - by Arran - 12-14-2018, 01:14 AM
