17 Chassis
The 17B front panel is removable as with all the "Clyde Shuler" style cabinets. The 17B cabinet is about 1/2 inch wider than a 91B cabinet. The 16B and the 17B cabinets are the same width and depth but the 16B is taller and has a larger dial opening. The 17B cabinet is the only cathedral cabinet that will work with a 17 chassis.
M R Radios   C M Tubes
17 Chassis - by Dwartz Farquhartz - 12-13-2018, 05:42 PM
RE: 17 Chassis - by Radioroslyn - 12-13-2018, 07:41 PM
RE: 17 Chassis - by klondike98 - 12-13-2018, 08:36 PM
RE: 17 Chassis - by Steve Davis - 12-13-2018, 10:08 PM
RE: 17 Chassis - by Radioroslyn - 12-13-2018, 10:53 PM
RE: 17 Chassis - by Steve Davis - 12-14-2018, 07:58 AM
RE: 17 Chassis - by Steve Davis - 12-14-2018, 08:01 AM
RE: 17 Chassis - by Dwartz Farquhartz - 12-14-2018, 06:27 PM
There are currently 10165 online users. [Complete List]
» 1 Member(s) | 10164 Guest(s)
