Zenith 7H920 AM/FM set 7 tube
#43
Good fix!
I'm taking notes, as the Zenith chassis on my workbench seems to have a very similar system for FM tuning.
Zenith 7H920 AM/FM set 7 tube - by jcassity - 11-30-2018, 03:04 PM
RE: Zenith 7H020 AM/FM set 7 tube - by jcassity - 11-30-2018, 03:11 PM
RE: Zenith 7H020 AM/FM set 7 tube - by jcassity - 11-30-2018, 03:12 PM
RE: Zenith 7H920 AM/FM set 7 tube - by David - 11-30-2018, 07:41 PM
RE: Zenith 7H920 AM/FM set 7 tube - by David - 11-30-2018, 07:51 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-01-2018, 01:01 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-01-2018, 08:55 PM
RE: Zenith 7H920 AM/FM set 7 tube - by David - 12-01-2018, 09:22 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-02-2018, 10:32 AM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-02-2018, 11:58 AM
RE: Zenith 7H920 AM/FM set 7 tube - by David - 12-02-2018, 12:31 PM
RE: Zenith 7H920 AM/FM set 7 tube - by KCMike - 12-02-2018, 01:17 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-02-2018, 01:45 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-02-2018, 02:46 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-02-2018, 04:45 PM
RE: Zenith 7H920 AM/FM set 7 tube - by David - 12-02-2018, 08:24 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-02-2018, 09:00 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-02-2018, 09:02 PM
RE: Zenith 7H920 AM/FM set 7 tube - by David - 12-02-2018, 10:10 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-03-2018, 11:33 AM
RE: Zenith 7H920 AM/FM set 7 tube - by David - 12-03-2018, 08:26 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-03-2018, 10:10 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-04-2018, 09:08 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-04-2018, 09:33 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-04-2018, 10:18 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-05-2018, 10:27 AM
RE: Zenith 7H920 AM/FM set 7 tube - by EdHolland - 12-05-2018, 02:30 PM
RE: Zenith 7H920 AM/FM set 7 tube - by David - 12-05-2018, 05:22 PM
RE: Zenith 7H920 AM/FM set 7 tube - by David - 12-05-2018, 08:41 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-05-2018, 10:53 PM
RE: Zenith 7H920 AM/FM set 7 tube - by Arran - 12-07-2018, 03:08 AM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-07-2018, 09:29 AM
RE: Zenith 7H920 AM/FM set 7 tube - by David - 12-07-2018, 02:04 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-07-2018, 10:06 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-08-2018, 09:27 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-09-2018, 11:59 AM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-09-2018, 12:02 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-14-2018, 10:27 AM
RE: Zenith 7H920 AM/FM set 7 tube - by EdHolland - 12-14-2018, 02:41 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-14-2018, 04:27 PM
RE: Zenith 7H920 AM/FM set 7 tube - by LarryFS - 12-14-2018, 05:51 PM
RE: Zenith 7H920 AM/FM set 7 tube - by TV MAN - 12-15-2018, 11:48 AM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-15-2018, 02:16 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-17-2018, 08:13 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-18-2018, 08:25 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-18-2018, 10:01 PM
RE: Zenith 7H920 AM/FM set 7 tube - by David - 12-18-2018, 10:41 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-19-2018, 10:15 AM
RE: Zenith 7H920 AM/FM set 7 tube - by Ed Locker - 12-19-2018, 10:54 AM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-19-2018, 12:10 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-19-2018, 12:11 PM
RE: Zenith 7H920 AM/FM set 7 tube - by Ed Locker - 12-19-2018, 03:19 PM
RE: Zenith 7H920 AM/FM set 7 tube - by jcassity - 12-19-2018, 08:13 PM
There are currently 9917 online users. [Complete List]
» 2 Member(s) | 9915 Guest(s)
