  • 3 Vote(s) - 2.33 Average
AM transmitter build - by Tim
#46
Interesting, and similar to an experience I had recently. A while back, I bought a nice Yaesu shortwave receiver. It suffered from terrible hum on some AM stations, but going up in frequency to the shortwave section, this diminished and went away.
I was convinced there must be an issue in the PSU, so replaced the caps, and bridge rectifier. No change. One day I had run the car down into the garage with the radio running, and noticed a hum that had not been present while driving. The garage is right beside my radio room. Eventually, I traced the hum to a USB charger I was using as a power supply for another radio project. Grounding the negative lead of the charger cured the hum - presumably a modulation hum of some kind on both radios.
So, I think you are on the right track with your detective work. With my case, certain stations in the AM broadcast range were affected more than others. I would suggest testing your transmitter at several different frequencies if possible. Also, check general reception of broadcast stations to see if there is any 60 Hz or 120 Hz present - and are any stations affected when the transmitter is running.
Good hunting!
Ed
AM transmitter build - by Tim - by TV MAN - 03-01-2018, 02:48 PM
RE: AM transmitter build - by Tim - by TV MAN - 03-01-2018, 02:58 PM
RE: AM transmitter build - by Tim - by sam - 03-01-2018, 03:51 PM
RE: AM transmitter build - by Tim - by fenbach - 03-01-2018, 09:08 PM
RE: AM transmitter build - by Tim - by 35Z5 - 03-01-2018, 11:35 PM
RE: AM transmitter build - by Tim - by TV MAN - 03-02-2018, 12:00 AM
RE: AM transmitter build - by Tim - by TV MAN - 03-02-2018, 12:32 AM
RE: AM transmitter build - by Tim - by 35Z5 - 03-02-2018, 12:29 PM
RE: AM transmitter build - by Tim - by Phlogiston - 03-02-2018, 01:29 PM
RE: AM transmitter build - by Tim - by TV MAN - 03-02-2018, 03:48 PM
RE: AM transmitter build - by Tim - by sam - 03-05-2018, 02:14 PM
RE: AM transmitter build - by Tim - by TV MAN - 03-09-2018, 12:37 PM
RE: AM transmitter build - by Tim - by Phlogiston - 03-10-2018, 11:33 AM
RE: AM transmitter build - by Tim - by TV MAN - 03-10-2018, 01:13 PM
RE: AM transmitter build - by Tim - by Phlogiston - 03-10-2018, 01:22 PM
RE: AM transmitter build - by Tim - by 35Z5 - 03-10-2018, 03:20 PM
RE: AM transmitter build - by Tim - by sam - 03-11-2018, 06:30 PM
RE: AM transmitter build - by Tim - by TV MAN - 03-21-2018, 10:56 PM
RE: AM transmitter build - by Tim - by TV MAN - 03-23-2018, 12:11 AM
RE: AM transmitter build - by Tim - by 35Z5 - 03-23-2018, 09:37 PM
RE: AM transmitter build - by Tim - by TV MAN - 03-24-2018, 08:36 PM
RE: AM transmitter build - by Tim - by TV MAN - 03-26-2018, 11:30 PM
RE: AM transmitter build - by Tim - by 35Z5 - 03-28-2018, 07:52 AM
RE: AM transmitter build - by Tim - by TV MAN - 04-08-2018, 03:54 PM
RE: AM transmitter build - by Tim - by TV MAN - 10-29-2018, 10:01 AM
RE: AM transmitter build - by Tim - by EdHolland - 11-02-2018, 12:08 AM
RE: AM transmitter build - by Tim - by morzh - 11-02-2018, 11:18 AM
RE: AM transmitter build - by Tim - by EdHolland - 11-02-2018, 04:50 PM
RE: AM transmitter build - by Tim - by TV MAN - 11-05-2018, 02:40 PM
RE: AM transmitter build - by Tim - by jcassity - 11-07-2018, 04:34 PM
RE: AM transmitter build - by Tim - by TV MAN - 11-12-2018, 01:00 PM
RE: AM transmitter build - by Tim - by TV MAN - 11-20-2018, 06:47 PM
RE: AM transmitter build - by Tim - by Eliot Ness - 11-20-2018, 09:13 PM
RE: AM transmitter build - by Tim - by TV MAN - 11-25-2018, 06:30 PM
RE: AM transmitter build - by Tim - by KCMike - 11-25-2018, 06:56 PM
RE: AM transmitter build - by Tim - by Phlogiston - 11-25-2018, 07:17 PM
RE: AM transmitter build - by Tim - by TV MAN - 11-26-2018, 12:00 PM
RE: AM transmitter build - by Tim - by TV MAN - 11-26-2018, 05:07 PM
RE: AM transmitter build - by Tim - by TV MAN - 11-30-2018, 09:19 PM
RE: AM transmitter build - by Tim - by TV MAN - 11-30-2018, 09:30 PM
RE: AM transmitter build - by Tim - by 35Z5 - 11-30-2018, 10:44 PM
RE: AM transmitter build - by Tim - by TV MAN - 12-14-2018, 06:38 PM
RE: AM transmitter build - by Tim - by EdHolland - 12-14-2018, 08:24 PM
RE: AM transmitter build - by Tim - by TV MAN - 12-15-2018, 11:02 AM
RE: AM transmitter build - by Tim - by Phlogiston - 12-23-2018, 12:27 PM
RE: AM transmitter build - by Tim - by TV MAN - 01-29-2019, 02:00 PM
RE: AM transmitter build - by Tim - by TV MAN - 01-29-2019, 02:28 PM
RE: AM transmitter build - by Tim - by sam - 01-29-2019, 02:38 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 2490 online users. [Complete List]
» 1 Member(s) | 2489 Guest(s)
