Block Capacitor Questions
Be careful, some of the blocks have more than capacitors in them (resistors) that don't need to be replaced unless they are damaged in the removal process.
Block Capacitor Questions - by Philco444 - 12-14-2018, 11:30 PM
RE: Block Capacitor Questions - by morzh - 12-15-2018, 12:12 AM
RE: Block Capacitor Questions - by Philco444 - 12-15-2018, 12:57 AM
RE: Block Capacitor Questions - by klondike98 - 12-15-2018, 10:00 AM
RE: Block Capacitor Questions - by Phlogiston - 12-15-2018, 06:47 PM
RE: Block Capacitor Questions - by klondike98 - 12-15-2018, 07:45 PM
RE: Block Capacitor Questions - by Philco444 - 12-15-2018, 07:58 PM
RE: Block Capacitor Questions - by Philco444 - 12-15-2018, 08:21 PM
RE: Block Capacitor Questions - by Philco444 - 12-15-2018, 11:15 PM
RE: Block Capacitor Questions - by klondike98 - 12-16-2018, 11:29 AM
RE: Block Capacitor Questions - by Philco444 - 12-16-2018, 04:39 PM
RE: Block Capacitor Questions - by Philco444 - 12-16-2018, 04:59 PM
RE: Block Capacitor Questions - by Phlogiston - 12-16-2018, 05:45 PM
RE: Block Capacitor Questions - by klondike98 - 12-16-2018, 05:47 PM
RE: Block Capacitor Questions - by Phlogiston - 12-16-2018, 06:23 PM
RE: Block Capacitor Questions - by klondike98 - 12-16-2018, 06:29 PM
RE: Block Capacitor Questions - by Philco444 - 12-16-2018, 10:42 PM
RE: Block Capacitor Questions - by Ron Ramirez - 12-17-2018, 07:22 AM
RE: Block Capacitor Questions - by Philco444 - 12-22-2018, 04:00 AM
