48-1262 speaker hook up mystery
Robbie Roberts Wrote:Chuck- Is that the same one for a 46-1203?
Scott
Yes, it is Scott. The D-10 was used in many of the 1946, 47 and 48 radio-phono models.
48-1262 speaker hook up mystery - by Guest - 02-09-2006, 10:07 AM
[No subject] - by Chuck Schwark - 02-09-2006, 11:55 PM
Thanks - by Guest - 02-10-2006, 12:03 AM
[No subject] - by Robbie Roberts - 02-10-2006, 12:06 AM
Re: Thanks - by Chuck Schwark - 02-10-2006, 12:09 AM
Recapping this radio - by Guest - 02-10-2006, 12:12 AM
[No subject] - by Chuck Schwark - 02-10-2006, 12:12 AM
Re: Recapping this radio - by Chuck Schwark - 02-10-2006, 12:15 AM
[No subject] - by Guest - 02-10-2006, 12:22 AM
[No subject] - by Chuck Schwark - 02-10-2006, 12:28 AM
[No subject] - by Guest - 02-10-2006, 12:40 AM
There are currently 10639 online users. [Complete List]
» 2 Member(s) | 10637 Guest(s)
