Adams Manufacturing Co. (Dial Belts) is Closing
I remember when GCHQ was going out of business. I ordered about $1K worth of grill cloth (I was still in business). It did seem pretty crazy, then. I have run out of several of the Zenith types (fortunately these are the ones being reproduced now though I still miss the GCHQ products). And, I am running low on some others - BUT it does not seem so crazy now.
With these values I think you are OK; the Cmax for this tube is 40uF. Your Vbb could rise a bit, but probably not too m...morzh — 04:53 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
There are currently 1899 online users. [Complete List]
» 3 Member(s) | 1896 Guest(s)
