1941 Philco escutcheon Screws
I have seen these screws at local hardware stores; I think I have even seen them at Lowe's. I bought some a while back to replace some screws on an early 1940s Philco escutcheon, but I don't remember where I bought them. Must be getting old. Hmpf. Icon_confused
1941 Philco escutcheon Screws - by AJB49 - 10-09-2010, 10:08 AM
Re: 1941 Philco escutcheon Screws - by AJB49 - 10-16-2010, 08:05 AM
Re: 1941 Philco escutcheon Screws - by Ron Ramirez - 10-16-2010, 08:24 AM
There are currently 8790 online users. [Complete List]
» 3 Member(s) | 8787 Guest(s)
